Deletes a user-created QoS profile.
QP2....QP7 | Specifies the user-created QoS profile you want to delete. |
N/A.
You cannot delete the default QoS profiles of QP1 and QP8. On a SummitStack, you also cannot delete QoS profile QP7. If you attempt to delete QoS profile QP7, the system returns an error.
All configuration information associated with the specified QoS profile is removed.
delete qosprofile qp3
This command was first available in ExtremeXOS 11.1.
